forry
Apr 16, 2020Initiate
Netgear D7000v2
After I lose power on My Nighthawk D7000v2 e.g. a minor power cut, or If i unplug it from the mains, l always lose the internet. The router reboots and looks normal but there is no internet connection. It's not automatically reconnecting. It only does so, when I go into the router and into the advanced tab and select internet setup and click on apply. Only after doing so, then the internet connection comes up. It is set to auto detect. I'am using this as a fibre router and not copper broadband settings.
Any Help appreciated
I think I have found the fix. I changed a setting. So I went to setup.Under Wan Preference,I changed the setting from Must use DSL Wan to "Must use Ethernet Wan".Click apply.
So to test it I turned the modem off and repowered the device. And I noticed the internet connection on the router came back automatically.Yay.
1 Reply
- forryInitiate
