Jeff_0926
Feb 19, 2021Follower
NetGear genie
I am currently taking a cyber security class and am needing to set my personal router to WPA-PSK [TKIP]. I can not find this option I have set mode: to 54 Mbps this option only displays WEP. Please any help would be appreciated. I will set it back to WPA2-PSK [AES] after project.
1 Reply
> Model: R6400|AC1750 Smart WiFi Router
Is that accurate? R6400[v1] or R6400v2? Look for "Model" on the
product label. Firmware version?> [...] I can not find this option [...]
Where did you look? What _did_ you find?
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for "Specify Basic WiFi Settings" and "Change the WiFi Security
Option".As plain-old WPA is increasingly being considered obsolete, there's
some chance that you'd need to load an old/obsolete firmware version in
order to use it.> I am currently taking a cyber security class [...]
Lesson zero:
