Joegsi's avatar
Joegsi
Follower
Aug 09, 2021
Netgear nighthawk AC1900/R7000 flashing power light
Hi there, I have an AC1900 which has been working fine. I recently went on holiday and on my return it no longer works and the power led flashes white constantly. The router was not touched or switched off. I have tried multiple restarts and factory resets with no luck. I cannot find the router on the router login page and CMD also shows no default gateway address for the router. Netgear genie also shows no router when I try to login. The internet light is also off. Any info would be appreciated
1 Reply
