fabrownii718's avatar
fabrownii718
Netgear Nighthawk C7800 Locked Out
I purchase this modem/router off Ebay in September 2020. It was listed as open box. I have been using it since with Spectrum 1gb and has been fine. Today it started losing internet and seems to rebot itself. I wanted to login to routerlogin.net and check some settings. Whoever I purchased from not only changed the router login username and password but they also changed the security questions so I cannot even recover the password. I have no contact with this person. Is there anything I can do?
I have included the picture of these security questions. I obviously have no idea what this person younger sisters name is.
  • You can factory reset it and get everything back to default.
    Simply push and hold reset for 7-15 seconds while its powered on.
    Then you'd need to re-install it.
  • plemans's avatar
    • fabrownii718's avatar
      fabrownii718
      What do you mean re-install it? I just plugged it in and used the SSID and password located on the back since I wasnt able to access anything.
