calypso1001's avatar
calypso1001
Netgear Nighthawk D7000 SNMP support for MRTG
HI Folks
I just replaced my old TPlink 1043ND and 8840T DSL modem with this D7000.  Is there special menu to enable snmp on this modem/router combo.
Below  what I used to get on my old Tplink 8840T.  Everytime I run MRGT config its fails.     Does this DSL modem actually support SNMP?
rgds
  • Thanks you are right no DD-WRT for D7000 ADSL/VDSL modem.  definitly not a R7000. Well let see if  a port for D7000 turns up in the database.
  • I never knew the D7000 existed.  Anyway, I think you are out of luck.  I'm pretty sure that SNMP is not supported on stock firmware.
    If you had a R7000, you could switch to 3rd party firmware, like DD-WRT, which supports SNMP.
    • calypso1001's avatar
      calypso1001
