samenchav's avatar
samenchav
Follower
May 12, 2023
Netgear Nighthawk issues - am i overloading it?
Hey all, i'll try to keep this brief.
I've recently moved in to a new house & have been in the process of smartify-ing it.
We're running everything off a Netgear Nighthawk & no matter what i do, the connect never stays solid.
We've got:
  • Hue bridge (Ethernet)
  • 7 Sonos Speakers (split across our tv & dining room)
  • 4 or 5 Nest Hubs
  • 2 Chrome Casts
  • 2 playstations (Ethernet - via a network switch)
  • 2 laptops
  • 2 Pcs (1 on ethernet)
  • 2 ipads
  • 2 phones
Several times a day *something* drops, however it's usually not the same thing. Right now one of my Nest hubs is working fine whilst another says it can't find the wifi & i'm going crazy.
I've tried a single SSID that combined both 5ghz & 2.4hgz & splitting them. I've turned off WMM & QoS. I'm not sure if it could be a issue of conflicting IP/Mac Address? Or if it's just a case of having too much on the internet.
I'm very out of my depth when it comes to this stuff & really have no idea where to start?
If anyone is able to assist I'd be much appreciative.
Thanks all.
1 Reply
  • FURRYe38's avatar
    What model NG router do you have?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    What do you mean by "Several times a day *something* drops".
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Set 20/40Mhz Coexistence to 40Mhz only. Under Advanced Tab/Advanced Settings/Wireless Settings
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
