MartinaHberg54's avatar
Aug 01, 2017
Netgear Nighthawk R7000 - Medion PC - can't see 5G Connection
Everything is working well iphone and Mac can connect to the 5G Port. But our other PC from Medion with Windows 10 from 2015 can not see/connect to 5G - only 2G. What I need to do? My son is very unhappy with the speed of 2G.
  • Hi MartinaHberg54,
    Check the adapter of the PC if it supports 5GHz. It could be the reason why it won't detect the 5Ghz.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi MartinaHberg54,
    • JamesGL's avatar
      JamesGL
      Hi MartinaHberg54,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
