remd
Sep 11, 2022Initiate
Netgear Nighthawk R7000 in Bridge mode + Wireless - Not working anymore
I have setup a R7000 in Bridge mode about 5 years ago and it was working fine including the Wifi network. I need this as I have a PFSense router that handles all settings and ips in the network. I r...
- Sep 11, 2022
thanks for your reply. I am on the latest R7000 firmware, just downloaded it from Netgear.
I got it to work, what I needed was the "AP Mode" not the Wireless bridge mode, the naming changed with the firmware update and got me confused.
So all good now
Sep 11, 2022Guru - Experienced User
What FW are you using?
When the R7000 is in Bridge mode, this mode is a wireless client bridge mode only. Means that the R7000 becomes a wifi client that needs to connect to a source wifi SSID signal. In this mode the R7000 will not broadcast a wifi signal for other devices to connect too.
I have mine in this mode right now and it's working as a client wifi device connected to my main Orbi system. A pc and game console connect to the R7000.
remd
So all good now
- FURRYe38Sep 12, 2022Guru - Experienced User
Glad you got it working. Yes AP mode would be the one.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
