farahtung
Oct 22, 2022Follower
Netgear Nighthawk R7000 Question
Hello all,
I was hoping for some insight regarding some recent issues with my router and if it is router issue or my abysmal WiFi.
Long story short, I have the Nighthawk R7000 and am experienced sporadic network disconnecting. I have to reset the router around 3-5 times a week for WiFi dropping for no apparent reason. Additionally, I experience significant networking issues playing most video games (of note, Warzone).
I have all home devices on the 2.4 GHz network, with maybe 1 or 2 devices on the 5 GHz network and plug my Xbox directly into the router. I have microwave internet and my WiFi download speed is around 10 Mbps download, and .70 upload (abysmal I know; I live in the country)
From reading through other posts, it appears that upgrading the firmware resolves that issue. However, I currently have the stock .88 firmware, with no upgrades available on the app.
Im considering trying a new router and then switching to literally any other internet providers (only other options here are satellite) but wanted to receive any input from y’all before I do so.
Thank you for taking the time to help
1 Reply
There have been about a dozen new updates since Firmware Version 1.0.9.88.
This is the latest.
R7000 Firmware Version 1.0.11.136 | Answer | NETGEAR Support
You could update it manually.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
