inkdoll
May 18, 2021Aspirant
netgear nighthawk r7000 shows offline on app
for days my wired connections wont connect. but the wifi will stay on. ill check my netgear app. and it will say offline. but in the device manager everythings connected. ill reset my router then everything will go back online. then after awhile the wired connections go offline again. i have no clue whats going on. ive reset the modem. ive reset my router. and it still happens
what modem do you have?
what firmware is on the router?
do the "offline" devices work? Or do they show "connected, no internet"
- inkdollAspiranti have the nighthawk 7000 router. filmware is V1.0.9.88_10.2.88 and only the wifi works. everything wired does not
What modem do you have? The R7000 is the router.
the 1.0.9.88 firmware isn't the current version.
You could try installing the current version, factory resetting, and reinstalling.
https://www.netgear.com/support/product/r7000.aspx
