forcemani's avatar
forcemani
Follower
Mar 27, 2023
Netgear Nighthawk router
My Netgear Nighthawk router specs say it can support 32 devices per band... If I add an AP via a hard-wired POE switch to one of the router's ports, do the devices on that AP count towards the 32 device limit? Or do they only count towards the AP's device limit?
FWIW... the devices connecting to the wireless AP will be assigned an IP via DHCP on the primary Nighthawk router.
  • plemans's avatar
    The AP devices won't count to the 32 device band limit.
    • michaelkenward's avatar
      michaelkenward
      Is that won't count in the 32 device limit or won't add to the 32 device limit?
      • plemans's avatar
        From what it sounded like the OP is connecting an access point to the router and wondering if the devices on the access points wireless will count against the 32 device limit per band on the router. (or i'm misreading it).
        If thats the case, it won't count as one of the 32 devices that the router is limited to on its own 2.4ghz/5ghz bands.
