SWAW-Jerry's avatar
SWAW-Jerry
Netgear Nighthawk WiFi Router Setup
I know you have to use a mobile App to configure the NightHawk routers now. My question is if I have the Netgear App on my iphone with a previous configured Nighthawk router, can I use it to configure one or two more Nighthawk routers?
  • plemans's avatar
    Dec 03, 2020
    yes you can.
    sometimes there's a screen saying to use the mobile app but if you look at the bottom of the browser window there's an option to continue using the browser.
  • plemans's avatar
    You don't have to use the app to configure router. I rarely do.
      • plemans's avatar
        yes you can.
