RAZ4
Oct 14, 2023Aspirant
Netgear Nighthawk X10 R9000
Hi, All i have recently started facing an issue with 5ghz, sometimes it doesn't show up. Sometimes does but not accepting connections. As soon as I try to connect it says couldn't connect. I have trie...
Oct 14, 2023Guru - Experienced User
If its actually 186 degrees, thats kind of an indicator.
Intel's specs for their wifi chips put their range up to 80 C.
The 186 F comes out to around 86c.
Thats pretty darned hot. You could try sticking a laptop cooler under it and seeing if it'd help keep it stable
