raschurchill100's avatar
Aug 01, 2022
Netgear Nighthawk x4s R7800 - periodic crash (white lighst stay on when crashed)
Hi All,
Normally this router has been really stable however over the last week it crashes once a day
Firmware V1.0.2.90 (standard netgear not a 3rd party firmware)
Access Point mode ethernet cable connected to BT router (full fibre)
2G and 5G using smart connect
Symptoms - will lock up with all white lights (except eSata and ethernet ports) will be permanently on (normally internet and wifi lights flash)
Done a factory reset and still same issue after reconfiguring the wifi settings back to what I had setup.
anyone else have the same issue?
  • FURRYe38's avatar
    What all devices do you have connected to it?
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Does the top of the router feel extra warm or hot to the touch when this happens?
  • Some thoughts:
    It is possible your firmware has become corrupted.  If you are happy with the firmware, re-flash the same version on top and then do a firmware default reset. Be sure and dismount/remove any USB or eSata devices prior.
    There are reports of R7800's that were assembled with memory chips that did not last more than a few programming cycles.  Did you buy your router new, how long have you owned your R7800?
    Check out for testing purposes the Voxel firmware here:  http://www.voxel-firmware.com/Downloads/Voxel/html/r7800.html
    Be sure and review the Read Me file at the top.  They have an active forum over on Small Net Builders https://www.snbforums.com/forums/netgear-ac-wireless.53/
    • raschurchill100's avatar
      raschurchill100
      I reflashed using the same firmware from netgear and that didnt' improve. So I'm now testing the Voxel version. Thanks for recommendations
      As to devices - nothing new to what I've had running for several months / years.
      • Kitsap's avatar
        Kitsap
        Master
        Thanks for the update.  Please let us know the results as your testing progresses.
