Swindonpete's avatar
Nov 23, 2020
Netgear Nighthawk X6 AC2200 Tri-Band Wi-Fi Extender and BT Broadband
Hi All - Could anyone help me - I've got a BT broadband connection with their latest router and I'm looking to buy a
Can anyone confirm it will be asimple set up and will work without needing to be a technical expert?
Really appreciate any help / advice please.
  • plemans's avatar
    It works for many but don't use the wps method of setup. Use the installation assistant.
    What actual router from them do you have.
    • Swindonpete's avatar
      Swindonpete
      Guide
      Hi Thnks for the quick response. I have the Smart Home Hub the one BT just sent me? Does that help?
      • plemans's avatar
        Not really. there should be a model number on the label.
