tishbite
Nov 04, 2016Aspirant
Netgear Nighthawk X6 (R8000)'s power goes off incessantly
My Netgear Nighthawk X6 (R8000)'s power goes off incessantly. We discovered that in the middle of demanding work, the network goes out, only to look at the signal lights of the Nighthawk, it is disco...
- AnonymousNov 05, 2016
10.0.0.1 is a problem in my opinion. It's caused when the r8000 is connected to another router AKA "Double Nat"
michaelkenward
Nov 05, 2016Guru - Experienced User
Have you tried it independently of the UPS?
Maybe it is playing up.
tishbite
Nov 05, 2016Aspirant
michaelkenward wrote:Have you tried it independently of the UPS?
No, I have not really tried powering the Nighthawk independent of UPS especially to aviod power cut off, and by extension - network distruption. I'll give it a trial now. I will let you know how it goes. If it works without UPS, then that would be another problem to resume investigations; until then.
Thank you Michael.
- michaelkenwardNov 05, 2016Guru - Experienced User
Just trying to eliminate variables. As the issue seems to be power rather than anything easily pinned on the router, that is where I would look first.
Another possibility is that the transformer is playing up.
If the other router has the same transformer, then swapping them around would also be worth trying.
- tishbiteNov 05, 2016Aspirant
michaelkenward wrote:Just trying to eliminate variables. As the issue seems to be power rather than anything easily pinned on the router, that is where I would look first.
Do you mean the internal transformer of the devices? Wouldn't that break warranty for the devices. Please explain better just in case I don't understand that aspect of transformer swap.
One quick question please. I discovered that in error the other router (which provides internet to the Nighthawk for broadcast) was confirgured with same Default Gateway IP Address (192.168.1.1) as the Nighthawk. Although the Nighthawk automatically reconfigured its Default Gateway IP Address (10.0.0.1) since it was set to DHCP. Could this have any effect to its power instability? Just wondering.
The R8000 power adapter should be 12VDC @ 5amps Make sure you didn't switch it.
