Nighthawk X6
1 TopicNetgear Nighthawk X6 (R8000)'s power goes off incessantly
My Netgear Nighthawk X6 (R8000)'s power goes off incessantly. We discovered that in the middle of demanding work, the network goes out, only to look at the signal lights of the Nighthawk, it is discovered that the indicator lights are either totally out or the power light shows amber. I initially thought it were a power issue, but it was plugged also to a UPS just as the other router in the office. I waited again to have the Nighthawk to come up, and when it does after a couple of minutes, we (devices - one at a time) try to reconnect to the Nighthawk x6 (monitioring the now beaming lights). The connection takes longer time, suddenly the once beaming light goes out totally leaving the power light to amber. Heck, this is not comfortable. Could someone tell me know if you experience this also and how could it be solved.Solved9.3KViews0likes15Comments
