mxie98's avatar
mxie98
Netgear R6080 Port farwarding not working
Hello,
I would like to set up remote desktop access. I have added custom service for port 3389 but It is not working. Please help.
Thanks,
mxie98
  •    I can't (yet) see your picture.  In-line images must be approved
    by a moderator before others can see them.  The time required varies.
    Attachments have no such limitation.  Of course, attachments have their
    own one-per-message limitation.  In the mean time, copy+paste is your
    friend.
    > [...] It is not working. [...]
       "not working" is not a useful problem description.  It does not say
    what you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
       For the usual problems with port forwarding, see:
          https://community.netgear.com/t5/x/x/m-p/1859106
    • mxie98's avatar
      mxie98
      Thank you for reply. following are more details of my problem.
      1) after i added service port 3389, I try remote access but i cannot even get to login page
      2) I cannot ping my public IP
      3) but I can telnet my Ip 3389
      4) I was able to get to my server remotely before i changed the router
      Attached please find my service screen
      Thanks,
      mxie98
      • antinode's avatar
        antinode
        Guru
        > [...] following are more details of my problem.
           Did you go through the "usual problems" tests in that cited thread?
        Plenty of unanswered questions there.
           Regarding "cannot", see "not a useful problem description [...]",
        above.
           Huh?  What does "try remote access" mean to you?  Why would port 3389
        have anything to do with it?
        above.
           "ping my public IP [address]" from _where_?  Actual command?  Actual
        error message?
           What is your "my public IP [address]"?  If you're worried about
        revealing secrets (like, say, a public IP address), then the top half of
        the address, "a.b" out of "a.b.c.d", would satisfy most of my curiosity.
        Or, plug that address into the form at: https://whois.arin.net/ , and
        see if it is a public or private address.
           "telnet" from _where_?
           What does "my Ip [address]" mean to you?  Do you, personally, have an
        IP address, or do you mean the IP address of some network interface in
        some device or other, or what?  Which part of "actual" was unclear to
        you?
           With my weak psychic powers, I know nothing about what you did
        "before", or what you changed to what.  Or why.
           That picture shows LAN IP addresses in the "10.0.0.*" subnet, which
        is typically the result of connecting the R6080 (WAN/Internet port) to
        the LAN of some other NAT router.
           Usual problem number 1 is number 1 for a reason.
