OneSpellWizard's avatar
Aug 20, 2021
NETGEAR R6700v3 hardwire connection slows down with CAT6 compared to CAT5e
As the title says, I have a strange situation with my download speed. I'm paying for 1gbps (gigabit) from Wave. For each speed I list here, I have tested it at least 2 times each on fast.com, speedtest.com, and google's speed test.
I have factory reset my router and reupdated to the latest firmware. QoS is off (if I turn it on, it slows down the speeds).
  • When I hardwire my desktop into my Arris Surfboard SB8200 modem with my 50 ft CAT6 cable, I get ~900mbps, which is great!
  • After I plug in my NETGEAR R6700v3 router to the modem using CAT5e, and my CAT6 cable for my desktop I get ~200 mbps
  • If I swap the Router -> Desktop connection to a CAT 5e cable, my speed tests jump to 800 mbps down.
Are there known issues if a different cable is used from modem -> router, and router -> desktop?
  • plemans's avatar
    Some devices are more sensitive than others to sketchy cat 5e cables. I'd be guessing that cable is boarderline.
    • OneSpellWizard's avatar
      OneSpellWizard
      Thanks for the reply! Sorry if it wasnt clear, I swapped the CAT6 cable (which already was able to get gigabit speeds if desktop plugged directly to the modem) for a CAT5e cable between desktop and router. The modem to router CAT5e cable was unchanged.
      • plemans's avatar
        Try factory resetting the r6700. after the reset, during the install process,make sure to leave qos, access control, parental controls, and traffic monitoring all disabled
