aless's avatar
aless
Netgear R6800 VPN broadcast network
Hello,
Is it possible to set up VPN servis to me same IP address as my home network (i.e 192.168.1.x), right now I get IP from different network (192.168.2.x)?
I need this for broadcasting service for control over my AC?
  • I have never seen any directed broadcast forwarding options on consumer grade routers.  It has long been a best practice for routers to drop directed broadcast due to concerns about DoS attacks.
  • It depends on the type of remote device.  If it's iPhone, then it only supports TUN style OpenVPN, which uses a different subnet.  You need a device that supports TAP style OpenVPN.
    • aless's avatar
      aless
      Thanks for the info. I use android (so TUN is my only option) - there is probably no broadcast forwarding options on my router to solve my issue?
