NGC2NGC
Mar 15, 2022Follower
Netgear R6850 dual band WiFi router, is https supported as login for admin
Is https supported as login for admin?
You can try and see if its supported.
Being this model is a bit older, it may not.
Check for Web Page Management option under Advanced tab/Admin
1 Reply
