PawelP
Dec 10, 2016Aspirant
NetGear R7000 dimension with antenna
Hi,
I'm going to purchase R7000 but I have some concerns if it fits into my closet.
Could anybody provide me with full height of this router (including antenna)?
Thanks in advance and best regards,
Pawel
About 8 inches.
About 8 inches.
- PawelPAspirant
Thank you very much.
Best regards,
Pawel
- michaelkenwardGuru - Experienced UserR7000 | Product | Support | NETGEAR The manual is there. Dimensions: 280 mm x 182 mm x 49 mm (11 in. x 7.17 in. x 1.9 in.) Remember, it needs air for cooling. (Operating temperature 0° to 40° C (32º to 104º F)) So don't pile your socks on it.
- PawelPAspirant
Thanks for the warning.
Actually it's a kind of RTV closet. It's open from the front side so I hope it gone be fine :)
Best regards,
Pawel
Sounds good. And you won't see the router's psychedelic light show
