krakesh
Feb 21, 2019Aspirant
Netgear R7000 firmware downgrade
Hi, I am planning to flash ddwrt image into Netgear R7000 router, for that the firmware version in the router should be V1.0.3.56 but currently the firmware version is V1.0.9.34_10.2.36 . So can you please help me to downgrade the firmare in my router.
If it can't be done I'm thinking to return the board as it of of no use to me, if I can't flash ddwrt image into that.
Thanks in advance.
Hello krakesh - Please refer to the following article as the same procedures apply.
https://kb.netgear.com/23960/How-do-I-manually-upgrade-firmware-to-my-NETGEAR-router
~Christian
- Christian_RNETGEAR Employee Retired
Hi krakesh - You can refer to the link below to view previous firmwares for the R7000.
https://www.netgear.com/support/product/r7000.aspx#download
~Christian
- krakeshAspirant
Hi Christian,
Thanks for responding. Actually I can able to find the firmware files, but I want to downgrade my firmware from 1.0.9.34 version to 1.0.3.56 version. Is it even possible?. If it is possible please do share the steps.
~Christian
