asphaltdragon's avatar
Jun 12, 2016
Netgear R7000 Nighthawk has spotty connection.
I just recently purchased an R7000 router, and it's working great... if you're on LAN. Any Wifi connections seem to have incredibly spotty connections. It'll load about 15 seconds of a Youtube video, wait around a minute, load another 15 or so seconds, wait a minute, etc, etc. My Steam downloads are downloading a few megabytes at a time every 30 seconds or so. I've tried just about every setting I could think of, and googled to see if there were other similar issues. It has just been updated to V1.0.5.64_1.1.88. Any ideas?
  • asphaltdragon's avatar
    asphaltdragon
    Jun 12, 2016
    I think I'm just going to go back to my DGL-5500. I know that works. Only reason I picked up the Nighthawk is because my moronic ISP thought my router was bad. And then it turned out to be their modem. At least I'll get the $200 I spent on the Nighthawk back. Thanks for all your help, Ether.
  • Did you perform a factory reset after updating?  A factory reset is a must-do especially if you upgraded from 1.0.4.30 or earlier.  The configuration settings are incompatible.  After you perform the reset, reconfigure all settings by hand.  Do not restore from a backup file saved with the earlier version because it, too, is incompatible.
      asphaltdragon
      I spoke too soon. Still having issues, though the connection appears a little more stable now. I'll try the factory reset and see what happens.
      • TheEther's avatar
        TheEther
        Guru
        That steam article could be a little more clear about which direction to open the ports.  You don't need to do anything in the outbound direction.  You only need to open ports for the inbound direction.  Also, if you using QoS, then try turning it off.  Sometimes, it hurts more than it helps.
