mitul's avatar
mitul
Netgear R7000 not letting cell phones connect to internet but laptops work fine
I have the router set up as access point, because I have another service set up as DHCP server host and providing ip addresses.  The internet light on my router is white, but on genie it says internet not connected.  Shows all attached devices on attached without any error message, but will not allow cell phones to connect to internet. Right now I am using my laptop without any issues.  I've tired both guest networks and regular network with same resaults.
  • Hi mitul,
    Welcome to NETGEAR Community!
    Was this working before?
    What is the firmware version of the router?
    Please try to forget WiFi network and connect again.
    Blanca
    Community Team
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi mitul,
    Blanca
    Community Team
    • Blanca_O's avatar
      Blanca_O
      Hi mitul,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
      Blanca
      Community Team
    • mitul's avatar
      mitul
      the firmware is uptodate, 1.0.9.32_10.2.34
      Before I had it set up in AP mode, which was was letting my server issue IP addresses and connect to network files but not letting wirelsess devices connect to the net.
      Now I have it set up as Router, but it issues its own ip address and will let me connect to net but not my local network b/c it issues ip address starting with 192 while my server issues ip address starting with 10.  Under wan set up i have told the router that the domain name server is my servers ip addess however it will not allow me to turn off DHCP (as soon as i turn this featur off, it will lose all connections and will not let any device connet to the router, I have to do factory reset and start all over.) and DHCP will not allow me to issue address that match my server ip address.
      • > I have the router set up as access point, because I have another
        > service set up as DHCP server host and providing ip addresses. [...]
           What is this "another service" (server?)?  Does it provide only
        client IP addresses, or does it also provide (appropriate) DNS server
        and default gateway addresses?
        > [...] will not allow cell phones to connect to internet. [...]
           What kind of "not allow" is this?  What's missing in the IP
        configuration of the (unspecified) "cell phones"?  Are they getting IP
        addresses?  DNS server addresses?  Default gateway addresses?
        > [...] Right now I am using my laptop without any issues. [...]
           And how is it connected to anything?  And what is its IP
        configuration?
              "My car doesn't work.  What's wrong with it?"
           That's bad enough.  Now add: "I have another car, and it works fine."
        What, exactly, is that supposed to tell anyone?
           If your DHCP server was doing its job properly, then I'd expect an
        R7000 in wireless-access-point mode to work properly, and that would
        normally be the best way to configure it.
           Marking this thread as "Solved!" may not have been the best way to
        get more help with this problem.
        > Now I have it set up as Router, [...]
           You can expect that to cause new and different problems.  Without
        knowing what the actual problem was when you had the R7000 configured as
        a WAP, I'd still advise configuring the R7000 as a WAP.  But, if you
        want to use two routers, ...
        > [...] will let me connect to net but not my local network b/c it
        > starting with 10. [...]
           That's one of the problems with cascading two routers.  When a system
        on your "10.u.v.*" subnet has a message for a system on your
        "192.168.1.*" subnet, it sees it as foreign (not "10.u.v.*"), and so it
        sends it to the outside world, where it gets lost.  To make this work,
        that system, or the router on the "10.u.v.*" subnet, needs to have an
        explicit route to the "192.168.1.*" subnet (using the R7000 as its
        gateway).  One solution would be to add a static route on the router for
        the "10.u.v.*" subnet like:
              Destination: 192.168.1.0/24
              Gateway:     <WAN/Internet address of the R7000>
           Naturally, that will work properly only if the WAN/Internet address
        of the R7000 is fixed (static or reserved), and so you would need to
        deal with that somehow.
           Knowing nothing about the main router on the "10.u.v.*" subnet, or
        the DHCP server there, makes it hard to offer specific advice.
