BoomerangTang
Jan 05, 2018Aspirant
Netgear R7000 not letting me login after putting it on AP mode
Hi, I remember first installing the R7000, I was displayed with either AP mode (not sure if that was what it was called) or regular mode. I chose AP mode, as I had slower connections on regular mode...
TheEther
Jan 05, 2018Guru
Log into the CG3000 and find the IP address for the R7000. Use that IP address to log into the R7000.
- BoomerangTangJan 06, 2018Aspirant
Hi,
I logged into my modem and went into the network map, but cannot seem to find my router. I already know the ip address to my router, typed it up and searched but would get "This site can't be reached".
I'm still able to connect to my router's wifi and still get internet access :/
- TheEtherJan 06, 2018Guru
When you enabled AP Mode on the Nighthawk, you will have been given the option to set the IP address using either DHCP or manually. The default option is DHCP. If you left it that way, then the Nighthawk will be assigned an IP address by your modem. And it will likely be a different address than what it used to be when the Nighthawk was in router mode.
Hi,
Yes, the router has a different IP address. I already knew the IP address of the router and the modem. So I tried typing the router's IP address, however, nothing would happen. I would get "This site can't be reached".
