eghaim
Nov 29, 2021Aspirant
netgear R7000
I have two Netgear R7000.
I wanted to see if I could have set one R7000 as base unit ant the other R7000 as a repeater. I did it without conneecting to internet.
It worked fine, but discovered seting as repeter is no security.
So, I reset the R7000 base unit, all went well, the R7000 repeter unit is now stock.
I am not able to reset becouse the repeater unit keeps trying to reboot every few minutes, the unit never boots up in order to reset.
Even in this condition I tryed pressing the reset button, first 7 seconds, then 30 seconds then 30/30/30 30 reset 30 reset with power off then 30 seconds reset with power on
help
All the spelling didn't correct
eghaim wrote:I have two Netgear R7000.
help
I have two Netgear R7000.I wanted to see if I could have set one R7000 as a base unit and the other R7000 as a repeater. I did it without connecting to the internet.
It worked fine but discovered setting as repeater is no security.
So, I reset the R7000 base unit, all went well, the R7000 repeater unit is now stock.
I am not able to reset because the repeater unit keeps trying to reboot every few minutes, the unit never boots up in order to reset.
Even in this condition, I tried pressing the reset button, first 7 seconds, then 30 seconds then 30/30/30 30 reset 30 reset with power off then 30 seconds reset with power on
help
- eghaimAspirant
help
help
Look at the Advanced Tab/Advanced Settings/Router mode option. Under here you may see Router, AP, Reapter or Bridge modes. If you don't see Repeater here, then the 7000 doesn't support Repeater mode.
- eghaimAspirant
Repeater worked perfectly, but I don't want to use it as a repeater. All I want is to reset to the factory setting.
