NguyenDo
Jul 12, 2016Aspirant
Netgear R7300DST can not use IPTV
Hi guys, I have a Netgear R7300 come with DST. However, I can not use IPTV, I also do the guide how to use IPTV on Netgear website but it couldn't work. Could you please help me to set up R7300 t...
- Aug 03, 2016
That's correct.
The model is intended to be used in the US and exclusively bought at BestBuy.
ElaineM
Jul 13, 2016NETGEAR Employee Retired
Hello NguyenDo
Welcome to the community!
Try to see if enabling IGMP will help.
The setting can be found by accessing the admin page then under WAN Setup.
NguyenDo
Jul 13, 2016Aspirant
Hi ElaineM,
Thanks for your reply. I also had tried to enable IGMP but it didn't work. Do you have any solutions?
