slsutton6's avatar
slsutton6
Netgear R7500v2 not broadcasting 5G network
Hello all,
Brand new router, latest firmware, 5GHz LED is illuminated, 5GHz service is turned on in the setup menu, and I can see the 2.4 GHz network and it operates normally, please advise.  And yes, the device I am using is 5GHz capable.
Thank you,
Stev
  • Hello James,
    I did not get a chance to troubleshoot the issue because the issue went away on its own and I have not been able to recreate it.
    Thanks,
    Steve
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi slsutton6,
    Update the firmware of the router. Reset and reconfigure after.
    • JamesGL's avatar
      JamesGL
      Hi slsutton6,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
      • slsutton6's avatar
        slsutton6
        Hello James,
        Thanks,
        Steve
