taloOLa's avatar
taloOLa
Follower
Sep 13, 2021
Netgear R7800 - Turn Remote Management Option Not Showing Up
Hi,
I simply can't find Turn Remote Management ON option.
Kindly please help :-)
Thank you.
  • FURRYe38's avatar
    What browser are you using? Try IE11, MS Edge or Firefox?
    Has a factory reset been performed since last update and setup from scratch?
    • FURRYe38's avatar
      So ya, This is all thats seen. I just updated my R7800 to v84 and factory reset and setup from scratch. I let the setup wizard enable FW updates and also saw it found a GUI update as well:
      Updated and still, all thats seen under Web Services Management:
      Is this new behavior for R7800? DarrenM
