DaveSanders's avatar
DaveSanders
Initiate
Jun 13, 2018
Netgear R7800 ethernet throughput issues
Netgear Nighthawk R78900 V1.0.2.52 firmware Windows 10
The R7800 is installed after an Arris Surfboard SB6183 cable modem.
Eperienced thoughtput issues about 2 months ago when the download speed dropped from ~180Mbps to ~93Mbps. Direct connection to the Arris moden restored the speed to ~180Mbps.
After checking R7800 settings I disabled Qos and the problem was resoved.
  • myersw's avatar
    myersw
    Jun 14, 2018
    Sounds right to me. QoS will slow a connection down which is what you experienced until disabling QoS. QoS will not allow full speed of the Internet connection.
    • myersw's avatar
      myersw
      Master
      • DaveSanders's avatar
        DaveSanders
        Initiate
        Hi Bill, what is strange is that I have had QoS enabled for a condiserable time prior to my experiences with the poor throughput performance and was getting around ~180Mbps download.
        Dave
