fleinbach's avatar
fleinbach
Netgear R8000p in bridge mode
      I replaced my old Nighthawk X8 that no longer works with a Netgear X6S Ac4000  R8000p. In the old setup I used the X8 in bridge mode with my fFIOS Actiontec router. Though I have read the instructions to setup Bridge mode for the X6s I cannot seem to make it work. When I select Bridge mode I can no longer access the Netgear router.
      First I will explain how I used the X8 in Bridge mode. I was able to connect the X8 via an ethernet cable to the Actiontec router. Then I was able to connect additional devices via the X8 both using ethernet ports and WIFI. This is what I want to do with the new X6S.
Is this possible or do I need to send back the X6S and change back to a new X8?
  • > First I will explain how I used the X8 in Bridge mode. [...]
       The fact that you need to explain what "bridge mode" means (to you)
    suggests that "bridge mode" is not a well-defined term, and that there's
    probably a better one.
    > [...] I have read the instructions to setup Bridge mode for the X6s
       Which "the instructions", where?
    > [...] When I select Bridge mode [...]
       How, exactly, did you do that?
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Read.  Look for "Use the
    Router as a WiFi Access Point".  For more helpful pictures, fetch the
    R7000 User Manual, and look there.
    • fleinbach's avatar
      fleinbach
         Which "the instructions", where? From the user manual on Netgear.
         How, exactly, did you do that?  Went to advanced tab: Advanced Setup,  Router/AP/Bridge Mode
      From your question it appears you are not familiar with the X6S settings. I attached a piture
      Access point mode does not work for my needs. I cannot use the ethernet ports in AP Mode.
      • antinode's avatar
        antinode
        Guru
        > settings. [...]
           I can read the User Manual, but I can't see what you did.
           No, a wireless access point is exactly what you want for this:
        > [...] I was able to connect additional devices via the X8 both using
        > ethernet ports and WIFI. [...]
           In bridge mode, I would not expect wireless access to be available,
        because the R8000P wireless stuff would be used to communicate with the
        main router.  In access-point mode, the Ethernet ports _should_ work.
