raphaelcampelo's avatar
Sep 21, 2021
Netgear R9000 - poor performance wired and wi-fi
Hi there, hope everybody is doing fine ...
I bought a NetGear R9000 AD7200 router 6 months ago, and until 10 days ago, everything was awesome. Suddenly, I noticed that I'm not getting more than 90MB/s of speed on both wired and wi-fi connections on any devices (notebooks, cellphones and tablets.
My carrier deliviers 400MB bandwith, using speedtest, I use to get 600MB when cable connected.
My firmware version is : 1.05.36
To check if the problem could be from the carrier side, I tested using a PPoE connection right from my notebook, and I'm really receiving full bandwith (400 MB).
I already tested several options, and it's relly clear to me that the issue is on the router.
Any help will be appreciated
  • Hi guys ... thanks a lot for the attetion. Today a received a technical guy from my carrier, and after some tests, he changed cable connector ... yes, just changed the connector, and everything is perfect again.
    I couldn't believe, but that's the fact. The issue was phisical.
    Thanks a lot for all the support and feedback here
  • plemans's avatar
    A couple things I'd try.
    1. the 90 mbps seems to indicate that your port speeds dropped from gigabit to 10/100mbps connection. You can check/confirm it with this guide: https://kb.netgear.com/24222/How-do-I-display-Internet-port-statistics-on-my-Nighthawk-router
    that'll who you the wan port connections link
    If its only 100mbps, then I'd start with replacing the cable. Try a cat 6 or better cable. I know cat 5e is gigabit rated but I've seen sketchy cables cause the drops to 10/100mbps.
    • Thank you for the feedbacl. I checked the statistics, and looks like the wired connection is 1000M as expected, but I'm getting the same behaviour on Wi-Fi too, it's really strange.
      regards,
      • plemans's avatar
        what modem are you connecting to?
        Did you try a simple factory reset?
