thechonch's avatar
May 09, 2020
Netgear Router Nighthawk not supported with Spectrum Internet
Listed here are all the Spectrum approved routers.
https://www.spectrum.net/support/internet/modems-routers-wireless-adapters/
I recently bought a Netgear Nighthawk router from amazon (AC1900 - Model C7000v2/C7000-100NAS).
Set it up and called Spectrum to activate my internet. I received a warning everytime I try go to a site saying something along the lines of: "This modem is not on compatible."
Called Spectrum again and asked about the situation. They said they block all other compatible modems that are not on the approved list (Link above).
I keep reading online that it is a working router with Spectrum. Does anyone have any news on the change of approve list?
- Thanks
Edit: Typos
Edit2: Mode number
  • Doing a factory reset on my router WNDR4300 with latest firmware solved the issue. Now I am able to get 89MBPS on 5g & 75MBPS on 2g. Thanks a lot.
  • plemans's avatar
    What modem or router did you buy?
    Model numbers help.
    You listed the A7000 which is a wireless usb adapter.
      • plemans's avatar
        The C7000 works with spectrum.
        And its on the qualified up to 400mbps list.
        And my in laws are running this same modem on spectrum with 200 mbps service.
        It potentially could be a line issue or just having a bad technician provisioning it.
  • Finally had some free time to work with tech support. Turned out the original person who tried activiating router was not the sharpest tool in the shed.
    New tech guy got me done in 10 mins. Thanks for the help all.
    • plemans's avatar
      Glad to hear you got it working!
