3v3ntH0riz0n
Dec 09, 2016Apprentice
NETGEAR Routers and CVE-2016-582384 security vulnerability
I am a bit concerned about this recent article: http://www.zdnet.com/article/two-netgear-routers-are-vulnerable-to-trivial-to-remote-hack/ https://www.kb.cert.org/vuls/id/582384 Details: Overview Net...
- Dec 11, 2016
NETGEAR is aware of the security issue #582384 affecting R6250, R6400, R6700, R6900, R7000, R7100LG, R7300DST, R7900, R8000, D6220, D6400 routers. Stay updated here: http://kb.netgear.com/000036386/CVE-2016-582384We now have beta firmware containing fixes for some affected models.
We're working hard on fixes for the other affected models and will update the security ticket above soon.
**** UPDATE from NETGEAR - Added by ChristineT on 12/15/16 at 10:30 AM PST ****
To our NETGEAR Community, we sincerely apologize for any complications you may have encountered due to the recently publicized vulnerability, referred to as VU 582384. We initially became aware of this vulnerability last Friday when CERT emailed us, and because we had no record of a prior report, we began our standard process of validation prior to making any public statements.
Once it had been disclosed that the first notification actually occurred in August, we conducted a search and confirmed this was the case. Admittedly, this was an oversight on our part. While no security reporting system is perfect, we aim to do better, and are evaluating how to improve our response process.
NETGEAR has created a channel for security researchers and other members of the public to contact us regarding potential security issues affecting NETGEAR products ([email protected]), which is publicly disclosed from the NETGEAR Product Security Advisory page. We receive numerous emails through this channel, the overwhelming majority of which, on review, do not raise product security issues. When we do recognize that there is a security risk to our customers, we work diligently to address them in a timely manner, as we have done in this case since learning about it last Friday.
Security Advisory for VU 582384 knowledgebase article.
netwrks
Dec 09, 2016Master
For R7000, there are options... Go here and load this firmware. Easy instructions on top page. Problem solved..
3v3ntH0riz0n
Sure, I could do something like that, but I would suspect that puts me out of support for this router. Not to mention I am one level behind because I don't want to run my arlo base station, my router manages the cameras. Really wish they would keep that going with newer builds. I am hoping that NetGear can add a comment here, saying they are at least aware and working on a fix. I'd rather know that they are going to do something, before putting a different os on the router. But thanks for that link. Question, did you attempt to load that on your router? Are you running that build now?
- Retired_MemberDec 09, 2016
When you bought the r7000 did it advertise the Arlo option?
Also I used the suggested FW without a problem.
- 3v3ntH0riz0nDec 09, 2016Apprentice
No it wasn't. It was a nice suprise with a firmware update, that they removed in the build shortly after. So you flashed out of your netgear OS on your router, using that link provided?
Yes! Several times. I wish it was available for the R8500
- netwrksDec 09, 2016Master
3v3ntH0riz0n wrote:Sure, I could do something like that, but I would suspect that puts me out of support for this router. Not to mention I am one level behind because I don't want to run my arlo base station, my router manages the cameras. Really wish they would keep that going with newer builds. I am hoping that NetGear can add a comment here, saying they are at least aware and working on a fix. I'd rather know that they are going to do something, before putting a different os on the router. But thanks for that link. Question, did you attempt to load that on your router? Are you running that build now?
I have 3 R7000's loaded with I believe 380_6.2.1. Used various version of Auswrt-Merlin firmware for a couple of years, with no issues. All 3 R7000's are powered off and up for sale now. I am running Unifi WAP's and a bunch of Ubiquity devices (router and switches). Grew tired of the home router consumer niche..
