3v3ntH0riz0n
Dec 09, 2016Apprentice
NETGEAR Routers and CVE-2016-582384 security vulnerability
I am a bit concerned about this recent article: http://www.zdnet.com/article/two-netgear-routers-are-vulnerable-to-trivial-to-remote-hack/ https://www.kb.cert.org/vuls/id/582384 Details: Overview Net...
- Dec 11, 2016
NETGEAR is aware of the security issue #582384 affecting R6250, R6400, R6700, R6900, R7000, R7100LG, R7300DST, R7900, R8000, D6220, D6400 routers. Stay updated here: http://kb.netgear.com/000036386/CVE-2016-582384We now have beta firmware containing fixes for some affected models.
We're working hard on fixes for the other affected models and will update the security ticket above soon.
**** UPDATE from NETGEAR - Added by ChristineT on 12/15/16 at 10:30 AM PST ****
To our NETGEAR Community, we sincerely apologize for any complications you may have encountered due to the recently publicized vulnerability, referred to as VU 582384. We initially became aware of this vulnerability last Friday when CERT emailed us, and because we had no record of a prior report, we began our standard process of validation prior to making any public statements.
Once it had been disclosed that the first notification actually occurred in August, we conducted a search and confirmed this was the case. Admittedly, this was an oversight on our part. While no security reporting system is perfect, we aim to do better, and are evaluating how to improve our response process.
NETGEAR has created a channel for security researchers and other members of the public to contact us regarding potential security issues affecting NETGEAR products ([email protected]), which is publicly disclosed from the NETGEAR Product Security Advisory page. We receive numerous emails through this channel, the overwhelming majority of which, on review, do not raise product security issues. When we do recognize that there is a security risk to our customers, we work diligently to address them in a timely manner, as we have done in this case since learning about it last Friday.
Security Advisory for VU 582384 knowledgebase article.
Unfiltered1
Dec 14, 2016Tutor
Netgear has fessed up to Tom's Hardware:
"This vulnerability, which has come to be referred to as VU 582384 was overlooked in our review process. We initially became aware of this vulnerability last Friday, December 9th, when CERT emailed us, and because we had no record of a prior report, began our standard process of validating prior to making any public statements. Once it had been disclosed that the first notification occurred in August, we conducted a search and confirmed this was the case. Admittedly, this was an oversight on our part. While no security reporting system is perfect, we aim to do better, and are evaluating how to improve our response process. "
http://www.tomshardware.com/news/netgear-responds-security-issue-routers,33199.html
tivoboy
Dec 14, 2016Guide
I alwasy love updates that require resetting ALL settings before doing the update. anyone have any tips for how to capture all the settings that are changed to make it easier to re-populate?
I have so many IP assignments, port forwarding, QOS, etc.. PIA for sure
- michaelkenwardDec 14, 2016Guru - Experienced User
tivoboy wrote:I alwasy love updates that require resetting ALL settings before doing the update.
Neat, isn't it?
Remember, these requirements are often "advisory".The "factory reset" thing depends on the severity of the changes that the firmware has inflicted on your hardware.
You can try other ways of doing it.
Here's my strategy, developed after beta testing various bits of kit:
- save (backup) settings
- flash firmware
If that works and you see no problems, great. If not, and something doesn't work, you may have to reset the device to the default settings:
- flash firmware
- set to factory settings
- retrieve settings from backup
If that works and you see no problems, problem fixed! If not:
- flash firmware
- set to factory settings.
- reconfigure everything
If that fails, then I fear that you may have to flash back to earlier firmware.
In this case, run the vulnerability test to check if the thing is fixed and if you need to go through the factory reset.
- ChrisNoonanDec 14, 2016Guide
What a grand opportunity for Netgear right now!
They are responding and appear to be taking a sound and responsible approach .... these things always take longer than the least anxious person expects ...
And the grand opportunity is to ensure the community is well served .... and to ensure the issues don't impact business materially .... time to think about dropping warranty limits and forgetting service revenues to make sure the community is well served and the vulnerabilities are expunged ... even on models and products, such as range extenders, which are not yet proven to be affected ....
What a grand opportunity!
- mdgm-ntgrDec 14, 2016NETGEAR Employee Retired
We have striven to keep the community up to date on our investigation.
Hardware warranty applies to hardware, software warranty applies to software issues, but when it comes to security we have a process described on our NETGEAR Product Security Advisory page for reporting what you consider to be a security issue. When emailing us as per those instructions the warranty status of your device is irrelevant.
- alokeprasadDec 14, 2016Mentor
Save (and restore) settings from the settings-backup file
Take pictures of the important screens (the old-fashioned way of backing up).
