3v3ntH0riz0n
Dec 09, 2016Apprentice
NETGEAR Routers and CVE-2016-582384 security vulnerability
I am a bit concerned about this recent article: http://www.zdnet.com/article/two-netgear-routers-are-vulnerable-to-trivial-to-remote-hack/ https://www.kb.cert.org/vuls/id/582384 Details: Overview Net...
- Dec 11, 2016
NETGEAR is aware of the security issue #582384 affecting R6250, R6400, R6700, R6900, R7000, R7100LG, R7300DST, R7900, R8000, D6220, D6400 routers. Stay updated here: http://kb.netgear.com/000036386/CVE-2016-582384We now have beta firmware containing fixes for some affected models.
We're working hard on fixes for the other affected models and will update the security ticket above soon.
**** UPDATE from NETGEAR - Added by ChristineT on 12/15/16 at 10:30 AM PST ****
To our NETGEAR Community, we sincerely apologize for any complications you may have encountered due to the recently publicized vulnerability, referred to as VU 582384. We initially became aware of this vulnerability last Friday when CERT emailed us, and because we had no record of a prior report, we began our standard process of validation prior to making any public statements.
Once it had been disclosed that the first notification actually occurred in August, we conducted a search and confirmed this was the case. Admittedly, this was an oversight on our part. While no security reporting system is perfect, we aim to do better, and are evaluating how to improve our response process.
NETGEAR has created a channel for security researchers and other members of the public to contact us regarding potential security issues affecting NETGEAR products ([email protected]), which is publicly disclosed from the NETGEAR Product Security Advisory page. We receive numerous emails through this channel, the overwhelming majority of which, on review, do not raise product security issues. When we do recognize that there is a security risk to our customers, we work diligently to address them in a timely manner, as we have done in this case since learning about it last Friday.
Security Advisory for VU 582384 knowledgebase article.
RELamb
Dec 18, 2016Aspirant
Thanks for the replies. I went ahead and closed the browser while the (hanging) update was taking place and everything seems to be okay with the router. The upload to the router must have never happened so I'll give it some time before attempting again (if ever).
GinaGerson
Dec 18, 2016Star
@RELamb Are you absolutly sure you got the right firmware for YOUR router? Otherwise, try to download it again from Netgear, maybe the file is incomplete or damaged.
And did you unzip the file? Just asking ;)
- michaelkenwardDec 18, 2016Guru - Experienced User
GinaGerson wrote:RELamb Are you absolutly sure you got the right firmware for YOUR router? Otherwise, try to download it again from Netgear, maybe the file is incomplete or damaged.
Heed this advice. It is important.
You should get an error if you have the wrong firmware, but this patch is such a rush job that who knows what is going on?
If your new firmware is not a beta version, you could try telling your modem/router to find and install the update. Instructions are in the manual for whatever box you have.
- katedan19772001Dec 19, 2016Aspirant
I have the netgear R7800 Nighthawk X4S AC2600 and when I try the recommonded advise to see if my router might be affected with the bug. I get the number 0 on the screen. Not a blank page or an error. It makes me think mines is affected with this issue. I used the http://[router-address]/cgi-bin/;uname$IFS-a . The router address being my router IP. The only response from a moderator is it's not in affected devices list.
Model # : R7800
Firmware: V1.0.2.12
OS: Windows 10
Browser: Chrome
- mdgm-ntgrDec 20, 2016NETGEAR Employee Retired
Model # : R7800
You can continue to monitor our security advisory page for this vulnerability to see if there is any change as our review continues.
- BoyceRensbergerDec 20, 2016Aspirant
It's definitely in Netgear's list of affected devices. That's what Netgear told me in an e-mail. Also see this: http://kb.netgear.com/000036540/R6250-Firmware-Version-1-0-4-6?cid=wmt_netgear_organic
My question was not that. It was whether the update via Genie covered the problem.
