3v3ntH0riz0n's avatar
3v3ntH0riz0n
Apprentice
Dec 09, 2016
NETGEAR Routers and CVE-2016-582384 security vulnerability
I am a bit concerned about this recent article: http://www.zdnet.com/article/two-netgear-routers-are-vulnerable-to-trivial-to-remote-hack/ https://www.kb.cert.org/vuls/id/582384 Details: Overview Netgear R7000 and R6400 routers and possibly other models are vulnerable to arbitrary command injection. Description CWE-77: Improper Neutralization of Special Elements used in a Command ('Command Injection') Netgear R7000, firmware version 1.0.7.2_1.1.93 and possibly earlier, and R6400, firmware version 1.0.1.6_1.0.4 and possibly earlier, contain an arbitrary command injection vulnerability. By convincing a user to visit a specially crafted web site, a remote attacker may execute arbitrary commands with root privileges on affected routers. A LAN-based attacker may do the same by issuing a direct request, e.g. by visiting: http:///cgi-bin/;COMMAND An exploit leveraging this vulnerability has been publicly disclosed. Impact By convincing a user to visit a specially crafted web site, a remote attacker may execute arbitrary commands with root privileges on affected routers. Solution The CERT/CC is currently unaware of a practical solution to this problem and recommends the following workaround. Discontinue use Exploiting this vulnerability is trivial. Users who have the option of doing so should strongly consider discontinuing use of affected devices until a fix is made available. --------------------------- Can someone from NetGear address this issue? I am running one level behind on my firmware, because I liked the fact that my router could double as my ARLO base station. However, reading this warning from CERT is causing me to be concerned. This router was not cheap, and I have had it for less than a year. If I have to get rid of it, becaue the issue cannot be resolved, then I would like some kind of compensation or trade in value. Regards.
  • NETGEAR is aware of the security issue #582384 affecting R6250, R6400, R6700, R6900, R7000, R7100LG, R7300DST, R7900, R8000, D6220, D6400 routers. Stay updated here: http://kb.netgear.com/000036386/CVE-2016-582384
    We now have beta firmware containing fixes for some affected models.
    We're working hard on fixes for the other affected models and will update the security ticket above soon.
    **** UPDATE from NETGEAR - Added by ChristineT on 12/15/16 at 10:30 AM PST ****
    To our NETGEAR Community, we sincerely apologize for any complications you may have encountered due to the recently publicized vulnerability, referred to as VU 582384. We initially became aware of this vulnerability last Friday when CERT emailed us, and because we had no record of a prior report, we began our standard process of validation prior to making any public statements.
    Once it had been disclosed that the first notification actually occurred in August, we conducted a search and confirmed this was the case. Admittedly, this was an oversight on our part. While no security reporting system is perfect, we aim to do better, and are evaluating how to improve our response process.
    NETGEAR has created a channel for security researchers and other members of the public to contact us regarding potential security issues affecting NETGEAR products ([email protected]), which is publicly disclosed from the NETGEAR Product Security Advisory page.  We receive numerous emails through this channel, the overwhelming majority of which, on review, do not raise product security issues.  When we do recognize that there is a security risk to our customers, we work diligently to address them in a timely manner, as we have done in this case since learning about it last Friday.
    Security Advisory for VU 582384 knowledgebase article.
  • Thanks slot Netgear, I like knowing my router just hit its expiration date from every tech news outlet.  Seeing recommendations that I shouldn't use the router from security officials is **bleep**ty when there was an opportunity to fix it
    • mdgm-ntgr's avatar
      mdgm-ntgr
      NETGEAR Employee Retired
      There is beta firmware with a fix available for your R7000 with production firmware on the way. Your router has not hit an "expiration date".
  • I flashed the beta firmware on my R6400 in the early hours and after some basic testing it seems the issue has been resolved.
    I tried 2 different tests, all done in Edge and Firefox.
    -Running the reboot command directly: Was prompted for credentials
    -Running the reboot command in a tab while another had routerlogin.net logged in: Was prompted for credentials once more
    The fact that a fix had come four months after being reported is still ridiculous, but at least I can now remain on stock firmware without jumping to open source solutions.
    • climb74's avatar
      climb74
      Guide
      SeaSalt, I gave up on actual support from netgear and flashed my device with DD-WRT.  At least I get actual support from the OpenSource community...  You would figure that a company who actually makes money on a product would take support of their product more seriously than someone doing the job in their spare time for free... but apparently that is not the case.  I owned the device less than a year and after spending a decent amount of money on it I had to wash my hands of the vendor... talk about disappointing!
      • meetloaf's avatar
        meetloaf
        Initiate
        Yeah, this is the last Netgear product I'll ever buy.
        I save my money to finally buy a nice premium router for my home, and this is the kind of treatment I get?
    • ElaineM's avatar
      ElaineM
      SeaSalt Thank you for the confirmation that the beta resolved it. I will forward it to our engineering team your feedback.
      Again, thank you and we appreciate your continued patience as we fix the issue.
      • SeaSalt's avatar
        SeaSalt
        Guide
        ElaineM Not a problem, I'm glad to hear a fix is on its way.
        Hopefully you can nudge the engineering team a bit regarding features that still aren't there (android VPN support, for example).
    • 3v3ntH0riz0n's avatar
      3v3ntH0riz0n
      Apprentice
      RC0101-2 wrote:
      Does this affect the r8500?
      You would have to test the sample code:
      Step 1 (optional): verify you’re vulnerable
      Open your browser and visit the following address:
      http://[router-address]/cgi-bin/;uname$IFS-a
      (For most people, this URL will work: http://www.routerlogin.net/cgi-bin/;uname$IFS-a)
      If a web page appears (which is not an error): you’re vulnerable. In my case, the page contains a text that starts with: Linux R7000 2.6.36.4brcmarm+ (...).
      Link to blog post for the rest: http://www.sj-vs.net/a-temporary-fix-for-cert-vu582384-cwe-77-on-netgear-r7000-and-r6400-routers/
      • RC0101-2's avatar
        RC0101-2
        Thank you...It looks like I am affected.  However, I follow the steps to kill the vulnerbility but it doesn't seem to work. After I follow the steps I recheck and I am still getting "Linixu r8500..."
        Any ideas? I have tried the router login and also my routers IP address....Maybe it's just time I move on from Netgear...
        *edit - I believe I got it working. I get a page cannot be displated when testing.  Still my confidence in Netgear is at an all time low and am thinking I will go with a different company.
  • GinaGerson
    The procedure kills the httpd, but it leaves telnetd running. Well, I guess it's better than a wide open web interface.
  • I have the Nighthawk X6 R8000 router and tried the exploit (using the "ls" command).  The router returned a directory listing. I was not logged into the router at the time, and the router requires authentication normally to log in.  So, it seems that the current software on the R8000 is also vulnerable !!!!!
    I hate to have to purchase a different router, but don't see how I can continue to use this one.  Hope a new software release will be available soon.
      • wawilmsn's avatar
        wawilmsn
        Guide
        My router is at 192.168.1.254.  First, I checked by going to the router web GUI and received the authentication page, since I was not logged in. I wanted to make sure my login was not cached.
        Then, I did exactly what you did. I copied your link with the "ls" in the line, substituting .254 for .1.
        Here is what I got back -- and yes, it is a partial HTML display, but it is a valid and proper response to the ls command -- it gave a directory listing:
        bin
        dev
        etc
        lib
        media
        mnt
        opt
        proc
        sbin
        share
        sys
        tmp
        usr
        var
        www
        I was using a Chrome browser on a Mac, but that should not matter. Bottom line - at least for me is that it ran the ls command.
        I am going to try to go back to a previous SW release and hope it works without the flaw.  Otherwise, I will have to try Tomato or DD-WRT, and I really do not want to have to do that and reset everything.
    • Coherent_Lite's avatar
      Coherent_Lite
      Guide
      I tested the exploit (to the best of my ability) and found that it does not seem to work with firmware version V1.0.3.68_1.1.31 .  The string causes the router to request the admin login and then fails to the "Unauthorized Access" screen.  The command after the semicolon does not appear to be executed.  Unfortunately, I could only test from my local network, so I cannot confirm whether this is a "universal fix".
      Although this is an older version of the firmware, it may be a work around while NetGear works up a patch.  I believe that some of the older versions are archived online.
      Regardless, be safe.
  • Count me in. Just bought this in July, and all Netgear can say is "uh, we know you spent $200 in this, but you shouldn't use it anymore"?
    I hope this changes soon
    • climb74's avatar
      climb74
      Guide
      So what is the timeline to a patch?  After spending over 200 bucks for a router I expect that the vendor is going to support their product.  Fair warning, I will be very vocal about my dissatisfaction if I have to go out and buy a new router.  Considering I have an extensive career in Information Security, my voice may carry some weight...  The current lack of response is disconcerting to say the least considering that there is an exploit available in the wild.
      • kochin's avatar
        kochin
        Apprentice
        I got a response from Netgear this morning at 2:39am. They must be working hard to get it resolved. But, the message isn't saying much.
        We appreciate you contacting us. Currently we are working on a fix and will get back to you when it’s available. Thanks.
        If you have any questions or comments with regard to this information, please contact us at: [email protected].
        Sincerely,
        Product Security Incident Response Team
        Netgear, Inc
      • JMNB's avatar
        JMNB
        Thank you all for your responses. Here's my specific complaints about the Netgear instructions for the security issue:
        I clicked on the link for "instructions" that came in the email alerting me to the problem. The first bit of advice was to connect your computer to the router via ethernet cable instead of using a wireless connection. There is no mention of what to do if, like millions of users, your laptop has no ethernet port.
        The first numbered bullet advises: "Write down all the settings which you changed from the default values since you may need to re-enter them manually." I have no idea what "default values" are so I went to the next step.
        Step number three asks you to log-in to the router. It asks for a user name and password. Up to that point I had never been to the Netgear site and therefore had no user name or passwrod. One of you helpful told me what to use, but why isn't that info on the log-in page. Or more importantly, why doesn't Netgear just log you in since EVERYONE is "admin" and the password is "password"?
        Finally, in the "important tips", it advises you that "The upgrade process is completed when the on-screen progress bar completes. If power light LED turns amber and blinking, POWER CYCLE THE ROUTER (caps added) to complete the upgrade." Power cycle the router? What does that even mean? How do you do it?
        Perhaps Netgear should have Community members review their proposed "instructions" before they release them to the general public.
        Thanks to all of you who responded so quickly.
        Jon (JMNB)
    • netwrks's avatar
      netwrks
      Master
      For R7000, there are options... Go here and load this firmware. Easy instructions on top page. Problem solved..
      • Captiva's avatar
        Captiva
        Tutor
        Very difficult if not impossible for 99% of Netgear customers (Costco, Amazon, Wal-Mart, Target shoppers) to comprehend and implement.  Vendor solution is needed.
