kotskop
Oct 11, 2021Aspirant
Network key
Hello,
I cannot locate the correct network password for my MR60 and all on line documentation refers back to changing passwords on the Netgear support web page which I can log on to, not the issue. Is there anyway to retrieve the router key? Right no I have obviously no wifi at all. Thanks
- kotskopAspirant
Ignore this, I think I understand a hard reset and therefore return to the label network and key is possible if you keep the reset button long enough. It still locked up the router so I pulled the power and put it back in, the routed default to the factory network and key
Netgear has set up a community forum specifically for the NightHawk MESH products. Most of the people who watch that forum are more likely to have experience with NH MESH products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Mesh-System/bd-p/en-home-nighthawk-mesh-systemGood Luck.
