jcash
Jan 24, 2024Follower
Network Name Change
If I change the name of my network do I have to re login all my devices or will the router populate the new name to each one?
If this is changing the wifi SSID name, then yes.
What NG product are you referring too?
If you're talking about SSID then yes you would.
I have a set ssid/password so whenever I change routers, all my devices just swap over without issues. It works great
