Jul 03, 2024Guru - Experienced User
New - R8000 Firmware Version 1.0.4.88 Released - Hot Fix
Security Fixes: 06/03/2024
- This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Download Link:
https://www.netgear.com/support/product/r8000.aspx#download
Firmware Update Instructions:
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit:https://www.netgear.com/support/product/R8000.aspx#docs
Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
This article applies to:
Let us know how it works for you...
- DLQAspirant
I had a problem where whenever I went in to change a connected device setting, for example, device priority or name, and clicked the Apply button, the admin page timed out, and i couldn't login again until I had restarted the router. Any changes I had made were lost. I have about 32 devices connected.
I hoped downloading this version of the firmware would fix the issue, but it doesn't.
I have no problem editing any of the other pages, DHCP Ip address reservation, or Dynamic QoS (which I have now turned off).
