Oct 16, 2024Guru - Experienced User
New - R8000 Firmware Version 1.0.5.88 Released
Security Fixes:
- This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security
- Security Advisory for Post-Authentication Command Injection on the R8000, PSV-2024-0022
- There maybe other items.
Download Link:
https://www.netgear.com/support/product/r8000.aspx#download
Firmware Update Instructions:
To update your router’s firmware, follow the instructions in your router’s user manual. To view your router’s user manual, visit:https://www.netgear.com/support/product/R8000.aspx#docs
Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
This article applies to:
This router is now EoL.
Let us know how it works for you...
I'm already running firmware 1.0.5.88 which is the latest but the download link I received from Netgear had me download V1.0.12.106 which looks like it's intended for an R7000. Should I try to install the firmware suggested to me by Netgear even though it says it's for an R7000?
v.88 is most current for the R8000. Had you had a R7000 any any point in history?
No. Here's a copy of part of the email I received:
Hi Ross,
NETGEAR strongly recommends that you update to the latest firmware version for your R8000 as soon as possible.
A Firmware update was released on Oct. 15, 2024, that addresses security vulnerabilities, however your R8000 has not been automatically updated and is running a firmware version earlier than 1.0.5.88.
