Garyrh66
Feb 23, 2019Apprentice
New firmware for AX8 1.0.1.56 available and not good results
Updated to the new firmware and it lowered my Wi-Fi speed. I have Comcast blast 250 Mbits. With 1.0.1.40 I was getting 300 Mbits down and with new firmware my speeds lowered to 50-70 Mbits. Back to 1...
- Feb 24, 2019
I found the problem. Login and change the 5g wireless channel to 153 and the mode to 2400Mbit. For some reason the new firmware changes this. All is back to normal now with my wireless speed which is back to 300Mbits.
Monstercastle2
Feb 23, 2019Aspirant
Same issue here, but haven't rolled back yet.
michaelkenward
Feb 24, 2019Guru - Experienced User
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
This is a nuisance because you then have to reconfigure the device all over again.
You can backup your settings before you reset and restore them later. But that may just bring back the fault. Then again, at least you will know if the reset fixed the problem.
- Garyrh66Feb 24, 2019Apprentice
Reset set the router to factory default and it did not fix the problem
- michaelkenwardFeb 24, 2019Guru - Experienced User
OK. Always worth trying.
The factory reset is more a "witchcraft" move than a technically informed solution, but it does seem to fix problems sometimes, especially on the wifi front.- Garyrh66Feb 24, 2019Apprentice
