Franardo316
Jul 26, 2021Aspirant
New Firmware upgrade R7000
I applied the new firmware upgrade and noticed a decline in speed in upload and download , is this normal. Will there be a fix?
Which firmware did you upgrade to?
Did you do a factory reset/reinstall after the update?
What speeds were you getting? And now?
Are thos speeds over 2.4gh? 5gh? wired?
How are you testing speeds? (device, website, app, etc)
- Franardo316Aspirant
- Franardo316AspirantI did a power cycle, a reset and reboot also, did not change anything. Is they’re a way to go back to previous firmware?
- Franardo316AspirantI’m thinking it’s an issue with the phone app, because even my devices list is missing entries
