JDFly
Oct 15, 2022Aspirant
New Installation - compatibility and recommendations
My XR8 router just died after 2+ years of service. I will be installing one of 3 systems. Two are NetGear, and the third the GoogleEros. As this is a NetGear community, I won’t ask for feedback on tha...
Oct 16, 2022Guru - Experienced User
I would say that I'm a fan of the triband setups versus the dual band. They're a bit more expensive but they preserve the bandwidth better than the dual band systems.
so I'd look at the RBK43 system if it was me. (they're cheap renewed on amazon) or the MK83 system for the mk nighthawk.
the 250ft is to far for wireless to work so you still might need to utilize some of your powerline devices to reach that far.
And both systems can have the extenders connected. They wont "integrate" into the mesh but you can connect them and use them.
