Tiff
Sep 11, 2017Guide
New Nighthawk X4S AC2600 Cannot find network
Setting up up new router...... Successful internet connection if hard-wired through the router. Looking for network on 2 laptops and one iPhone does not list the network name. I have changed the n...
- Sep 11, 2017
Thank you your suggestions but I finally found the issue on another board.
If you look closely the 2nd light on the right of the router is acutally a button. If you press and hold the button down for at least 5 seconds it works! How frustrating and a waste of yours and my time. Anyway thank you for your input
Tiff
Sep 11, 2017Guide
Forgot to mention, only 2 lights are on, starting from left. The power light and the internet connection light. There is no @2G/5G light lit.
- OCRBNSep 11, 2017AspirantSSID Broadcast has to be enabled.
You have to log in the web interface then in Advanced > Wireless you can enable it.
