Tiff
Sep 11, 2017Guide
New Nighthawk X4S AC2600 Cannot find network
Setting up up new router...... Successful internet connection if hard-wired through the router. Looking for network on 2 laptops and one iPhone does not list the network name. I have changed the n...
- Sep 11, 2017
Thank you your suggestions but I finally found the issue on another board.
If you look closely the 2nd light on the right of the router is acutally a button. If you press and hold the button down for at least 5 seconds it works! How frustrating and a waste of yours and my time. Anyway thank you for your input
OCRBN
Sep 11, 2017Aspirant
That's weird... I just tried to disable the 2.4G wireless router radio and the corresponding light on the router turned off and I couldn't find that network. Only the 5G was available.
Then I enabled it and everything was working.
Maybe you can try to reset your router...
Tiff
Sep 11, 2017Guide
- OCRBNSep 11, 2017AspirantI knew about that button but that was so obvious that I didn't think about it... I was focused on a configuration issue.
Well, enjoy your Wi-Fi connection !
