ng_husker's avatar
Jan 24, 2021
New R7000 firmware 1.0.11.116 failure to update
Just found the latest firmware updated here:
https://www.netgear.com/support/product/r7000.aspx#download
Unzipped the download, and tried to update the firmware *.chk file using the Upload button.  It fails with this error message:
<quote>Failure! This firmware file is incorrect! Please get the firmware file again and make sure it is the correct firmware for this product.</quote>
  • Netgear must have updated the 1.0.11.116 download, because this week I tried again, and this time it installed successfully.  Not sure what the issue is, but clearly Netgear updated the patch.  Darn I wish I had kept the old download, could've checked sized and diffed it against the new one.
  • michaelkenward's avatar
    michaelkenward
    What version do you have now?
    You do own the R7000 and not the R7000P?
    • ng_husker's avatar
      ng_husker
      Guide
      Yep as in my OP:  Model: R7000|AC1900 Smart WIFI Router
      Version:  V1.0.11.106_10.2.100
      Thx.
        ng_husker
        Guide
