Praisehym's avatar
Praisehym
Initiate
Jun 23, 2021
New R7450 AC2600
Normally, to preconfigured a router I can either wire via Ethernet from my PC Ethernet port to any LAN port and type the router address in a browser and login to configure the router. Is there a mandate for an internet connection now?
I could even connect via wireless and that would work. Now neither work.
  • I' currently have the r6400 and have been looking to upgrade just a big since I've moved into a bigger house and increased internet needs and speeds. Saw that Wally World is going to have the 7450 on sale Black Friday for $99 and was thinking of snagging that. I know I will see an increase in performance between the two but how noticeable will it be?
    myaarpmedicare.com
  • plemans's avatar
    No you can still use that method. I swap routers regularly and thats my prefered method.
    What error are you getting?
    (there might be an option at the bottom of the screen that says something like "I don't have a mobile device" that you can click on)
    • Praisehym's avatar
      Praisehym
      Initiate
      No error. I opened chat support feed and the person answering made that statement that we needed internet to configure the router. Sent a lot of instructions that supported that theory. Admittedly an internet connection would make it a little easier but, not having one doesn’t mean it can’t be done. I retired a few years back as a network engineer from HP. I’ve configured a lot of commercial grade routers and switches and, like you, I prefer to pre-configure then drop it in with little or no surprises. I got it going after getting my PC to set the router as my default gateway and observing how certain panels responded when moving around inside the router after restoring the firmware manually. Firmware was suspected to be corrupted. Thanks.
