Benle500
Oct 09, 2021Aspirant
New Router Modem with Same SSID and Password with Old Router
I am replacing my old Netgear modem/router combo to a new Netgear modem/router combo model C2020/AC1200. I have more than 20 WiFi devices on the old modem/router. Do all my WiFi devices continue to w...
michaelkenward
Oct 10, 2021Guru - Experienced User
Benle500 wrote:
Do all my WiFi devices continue to work if I change the same SSID and password from the old router to the new router so I do not to reconfigure all the WiFi devices?
That may depend on what these wifi clients are.
Try it and see.
I can't find anything in the Netgear system that claims to be a C2020. CXXX usually means that it is a cable modem/router. You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
Benle500
Oct 10, 2021Aspirant
Sorry the wrong model. It is C6220 not C2020.
- michaelkenwardOct 10, 2021Guru - Experienced User
No problem. I was just puzzled.
The answer is the same.
You lose nothing by trying the same SSID. Many of us do that all the time.
You may have to reboot some of the wifi clients. But who knows?
